Support Questions
Check Script problem with SLES 12 Installation
Solved Go to solution
When installing with Cloudera Manager over SLES 12 SP2 platform, installation process is stopped after "cloudera-manager-agent" package check.
This is the server log:
END (0)
BEGIN zypper info cloudera-manager-agent | grep -E 'Version:[[:space:]]5.9.1-.*\.8'
END (1)
cloudera-manager-agent must have Version=5.9.1 and Build=8, exiting
closing logging file descriptor
And the problem seems to be in the zypper info output. In scm_prepare_nodexxxx.sh scripts, the pattern "Version:[[:space:]]5.9.1-.*\.8" is not correct, because in SLES 12 SP2, zypper info returns a tab, not a space, after "Version" word. Then ,validation is null, and install process is stopped.
The output in SLES 12 is in attached output.png file
1 ACCEPTED SOLUTION
Accepted Solutions
Re: Check Script problem with SLES 12 Installation
Expert Contributor
SLES12 SP2 does not install CM5.9.0.  My installation failed also.
I can't find any documentation that says it is a supported platform for CM5.9.0.
Sorry
5 REPLIES 5
Expert Contributor
Sounds like your Cloudera Manager Server is not running 5.9.1, but you are trying to install the 5.9.1 agent.
What version of the CM Server do you have running?   Lookin the CM UI drop down SUPPORT > ABOUT  top rigth hand corner on CM UI home page
The server and agent versions have to match.
Tina
Hi,
Not in this case, versions are right. The problem, in my opinion, is under
the validation script of cdm_install, marked in the attach, where script is
not well detecting "Version" in zypper info output
Really versions are right.
This is my CM Version:
*Proveedor de VM de Java*: Oracle Corporation
*Versión de Java*: 1.8.0_121
*Hora del servidor*: 25-ene-2017 18:06:37, Hora de Europa Central (CET)
Copyright © 2011-2017 Cloudera, Inc. Todos los derechos reservados.
Hadoop y el logotipo del elefante de Hadoop son marcas comerciales de
Apache Software Foundation.
Thanks for the reply
Expert Contributor
I don't see the CM Version in your reply, I assume it says:
Version: Cloudera Enterprise Data Hub Edition Trial 5.9.1 (#8
I will try to install this on SLES12 SP2 now.
Will let you know if it works for me.
Tina
Expert Contributor
Sorry
Hi, sure, it was a recomendation for future developments :-)
Thanks a lot, finally we'll change the OS.
Don't have an account?
