Created 01-25-2017 07:38 AM
When installing with Cloudera Manager over SLES 12 SP2 platform, installation process is stopped after "cloudera-manager-agent" package check.
This is the server log:
END (0)
BEGIN zypper info cloudera-manager-agent | grep -E 'Version:[[:space:]]5.9.1-.*\.8'
END (1)
cloudera-manager-agent must have Version=5.9.1 and Build=8, exiting
closing logging file descriptor
And the problem seems to be in the zypper info output. In scm_prepare_nodexxxx.sh scripts, the pattern "Version:[[:space:]]5.9.1-.*\.8" is not correct, because in SLES 12 SP2, zypper info returns a tab, not a space, after "Version" word. Then ,validation is null, and install process is stopped.
The output in SLES 12 is in attached output.png file
Created 01-25-2017 09:01 AM
SLES12 SP2 does not install CM5.9.0. My installation failed also.
I can't find any documentation that says it is a supported platform for CM5.9.0.
Sorry
Created 01-25-2017 07:50 AM
Sounds like your Cloudera Manager Server is not running 5.9.1, but you are trying to install the 5.9.1 agent.
What version of the CM Server do you have running? Lookin the CM UI drop down SUPPORT > ABOUT top rigth hand corner on CM UI home page
The server and agent versions have to match.
Tina
Created 01-25-2017 07:57 AM
Created 01-25-2017 08:32 AM
I don't see the CM Version in your reply, I assume it says:
Version: Cloudera Enterprise Data Hub Edition Trial 5.9.1 (#8
I will try to install this on SLES12 SP2 now.
Will let you know if it works for me.
Tina
Sorry
Created 01-26-2017 12:26 AM
