Created on 02-16-2017 09:01 AM - edited 08-19-2019 04:35 AM
I would like to map the ResourceManager Web UI with Knox.
I've set up the topology like:
<service> <role>YARNUI</role> <url>http://{{rm_host}}:8088/</url> </service> <service> <role>HDFSUI</role> <url>http://{{namenode_host}}:50070/</url> </service>
But the browser can't load the .css and .javascript from RM UI. "This page will not function without javascript enabled. Please enable javascript on your browser."
I'm using Google Chrome but there are the same problems with Internet Explorer.
JavaScript is working and RM UI directly is working as well. Developer Tool from Chrome: Failed to load resource: the server responded with a status of 404 (Not Found)
Same Problems with NameNode UI.
Can somebody help me please, or are there known problems?
Thanks, Andreas
Created 02-16-2017 09:13 AM
You can try and add a / in your browser when you make the request.
Otherwise, look at the github code and replace the xmls for the services you have issues with the ones on github, for example replace /usr/hdp/current/knox-server/data/services/hdfsui/2.7.0/ with https://github.com/apache/knox/tree/v0.11.0/gateway-service-definitions/src/main/resources/services/...
Created 02-16-2017 09:30 AM
Thanks for your fast answer. I already tried it with a / at the end, I know this is a known bug in Oozie UI mapping..
I also replaced the service.xml and rewrite.xml with both github .xml's. After a Knox restart, the problems are still the same...
My URLs:
https://<our-knox-host>:8443/gateway/default/yarn/
https://<our-knox-host>:8443/gateway/default/hdfs/
Example call for Oozie (it's working without any problems):
Created on 02-16-2017 09:36 AM - edited 08-19-2019 04:35 AM
NameNode UI:
Created 02-16-2017 10:10 AM
What Knox / HDP version do you have?
It works fine on my HDP 2.5.3 Knox.
Have you also defined WEBHDFS and RESOURCEMANAGER in your topology?
Any errors in gateway.log and do you see the same 404s in gateway-audit.log?
Created 02-16-2017 10:29 AM
I'm using HDP 2.5.3 as well, with Knox version 0.9.0.2.5
Yes, I have also defined WEBHDFS and RESOURCEMANAGER like the default config in my topology, it's working without any problems:
<service> <role>NAMENODE</role> <url>hdfs://{{namenode_host}}:{{namenode_rpc_port}}</url> </service> <service> <role>JOBTRACKER</role> <url>rpc://{{rm_host}}:{{jt_rpc_port}}</url> </service> <service> <role>WEBHDFS</role> {{webhdfs_service_urls}} </service> <service> <role>WEBHCAT</role> <url>http://{{webhcat_server_host}}:{{templeton_port}}/templeton</url> </service> <service> <role>OOZIE</role> <url>http://{{oozie_server_host}}:{{oozie_server_port}}/oozie</url> </service> <service> <role>WEBHBASE</role> <url>http://{{hbase_master_host}}:{{hbase_master_port}}</url> </service> <service> <role>HIVE</role> <url>http://{{hive_server_host}}:{{hive_http_port}}/{{hive_http_path}}</url> </service> <service> <role>RESOURCEMANAGER</role> <url>http://{{rm_host}}:{{rm_port}}/ws</url> </service>
I see the same 404s in the gateway-audit.log for example:
access|uri|/gateway/default/hdfs/static/bootstrap-3.0.2/js/bootstrap.min.js|success|Response status: 404
Created 02-16-2017 05:38 PM
It's really strange @Andreas Schild I've replicated your configuration on my cluster and still works fine, IE or Firefox.
Let's try the following troubleshooting steps.
1) First make sure the topology file has actually been resolved with the correct values:
cat /etc/knox/conf/topologies/default.xml
2) Get from it the URL for HDFSUI, append /static/bootstrap-3.0.2/js/bootstrap.min.js to it and try it out in a curl, should be like this:
curl -i http://namenode:50070/static/bootstrap-3.0.2/js/bootstrap.min.js
3) I'd also want to see the full line the gateway-audit.log, mine shows additional information (like the service name) and also the dispatch:
17/02/16 17:15:53 ||c5f07e39-ab12-4a71-9283-f37a35128419|audit|HDFSUI|guest|||dispatch|uri|http://namenode:50070/static/bootstrap-3.0.2/js/bootstrap.min.js?doAs=guest|success|Response status: 200 17/02/16 17:15:53 ||c5f07e39-ab12-4a71-9283-f37a35128419|audit|HDFSUI|guest|||access|uri|/gateway/default/hdfs/static/bootstrap-3.0.2/js/bootstrap.min.js|success|Response status: 200
4) Check under /usr/hdp/current/knox-server/data/services/ if you have all services, I have:
ls -l /usr/hdp/current/knox-server/data/services/ total 0 drwxr-xr-x. 3 knox knox 18 Feb 7 09:41 ambari drwxr-xr-x. 3 knox knox 18 Feb 7 09:41 ambariui drwxr-xr-x. 3 knox knox 18 Feb 7 09:41 falcon drwxr-xr-x. 3 knox knox 19 Feb 7 09:41 hbase drwxr-xr-x. 3 knox knox 18 Feb 7 09:41 hbaseui drwxr-xr-x. 3 knox knox 18 Feb 7 09:41 hdfsui drwxr-xr-x. 3 knox knox 19 Feb 7 09:41 hive drwxr-xr-x. 3 knox knox 18 Feb 7 09:41 jobhistoryui drwxr-xr-x. 3 knox knox 18 Feb 7 09:41 oozie drwxr-xr-x. 3 knox knox 18 Feb 7 09:41 oozieui drwxr-xr-x. 3 knox knox 18 Feb 7 09:41 ranger drwxr-xr-x. 3 knox knox 18 Feb 7 09:41 rangerui drwxr-xr-x. 3 knox knox 18 Feb 7 09:41 sparkhistoryui drwxr-xr-x. 3 knox knox 18 Feb 7 09:41 storm drwxr-xr-x. 3 knox knox 18 Feb 7 09:41 storm-logviewer drwxr-xr-x. 3 knox knox 19 Feb 7 09:41 webhcat drwxr-xr-x. 3 knox knox 18 Feb 7 09:41 webhdfs drwxr-xr-x. 3 knox knox 18 Feb 7 09:41 yarn-rm drwxr-xr-x. 3 knox knox 18 Feb 7 09:41 yarnui
5) Stop Knox and delete/move /usr/hdp/2.5.3.0-37/knox/bin/../data/deployments/default*
Created 02-17-2017 05:54 AM
at first, thank you very much for your help!! We have a hardware firewall with DMZ enabled in our cluster. It blocks all ports except 8443 for knox. Do you think this might be a problem?
I checked your troubleshooting steps:
1.) Yes, the hostnames and ports are correctly resolved in default.xml
2.) curl on the namenode is working fine
curl -i http://our_namenode_host:50070/static/bootstrap-3.0.2/js/bootstrap.min.js HTTP/1.1 200 OK X-FRAME-OPTIONS: SAMEORIGIN Accept-Ranges: bytes Content-Type: application/x-javascript Content-Length: 27748 Last-Modified: Tue, 29 Nov 2016 20:33:00 GMT Server: Jetty(6.1.26.hwx)
3.) Checked the gateway-audit.log
17/02/17 06:49:42 ||7daf998a-1783-41a3-b3bd-008f588227b3|audit|HDFSUI||||access|uri|/gateway/default/hdfs/|unavailable|Request method: GET 17/02/17 06:49:42 ||7daf998a-1783-41a3-b3bd-008f588227b3|audit|HDFSUI||||access|uri|/gateway/default/hdfs/|success|Response status: 401 17/02/17 06:49:42 ||669c7b17-c633-4dfe-adac-68b88a5c0217|audit|HDFSUI||||access|uri|/gateway/default/hdfs/|unavailable|Request method: GET 17/02/17 06:49:44 ||669c7b17-c633-4dfe-adac-68b88a5c0217|audit|HDFSUI|<my_user>|||authentication|uri|/gateway/default/hdfs/|success| 17/02/17 06:49:45 ||2883703f-494a-4d99-8151-cf27b13e4924|audit|KNOX|<my_user>|||access|uri|/gateway/default/hdfs/static/dataTables.bootstrap.css|success|Response status: 404 17/02/17 06:49:45 ||d0b6cc4d-ed05-4b9a-beae-9b267d4dfc39|audit|KNOX||||access|uri|/gateway/default/hdfs/static/dust-helpers-1.1.1.min.js|unavailable|Request method: GET 17/02/17 06:49:45 ||d0b6cc4d-ed05-4b9a-beae-9b267d4dfc39|audit|KNOX|<my_user>|||authentication|uri|/gateway/default/hdfs/static/bootstrap-3.0.2/js/bootstrap.min.js|success| 17/02/17 06:49:45 ||d0b6cc4d-ed05-4b9a-beae-9b267d4dfc39|audit|KNOX|
<my_user>
|||authentication|uri|/gateway/default/hdfs/static/bootstrap-3.0.2/js/bootstrap.min.js|success|Groups: [<my_AD_groups>]4.) I checked
<user>@<knox_node>:/usr/hdp/current/knox-server/data/services> ll total 76 drwxr-xr-x 3 knox knox 4096 Dec 21 12:01 ambari drwxr-xr-x 3 knox knox 4096 Dec 21 12:01 ambariui drwxr-xr-x 3 knox knox 4096 Dec 21 12:01 falcon drwxr-xr-x 3 knox knox 4096 Dec 21 12:01 hbase drwxr-xr-x 3 knox knox 4096 Dec 21 12:01 hbaseui drwxr-xr-x 3 knox knox 4096 Dec 21 12:01 hdfsui drwxr-xr-x 3 knox knox 4096 Dec 21 12:01 hive drwxr-xr-x 3 knox knox 4096 Dec 21 12:01 jobhistoryui drwxr-xr-x 3 knox knox 4096 Dec 21 12:01 oozie drwxr-xr-x 3 knox knox 4096 Dec 21 12:01 oozieui drwxr-xr-x 3 knox knox 4096 Dec 21 12:01 ranger drwxr-xr-x 3 knox knox 4096 Dec 21 12:01 rangerui drwxr-xr-x 3 knox knox 4096 Dec 21 12:01 sparkhistoryui drwxr-xr-x 3 knox knox 4096 Dec 21 12:01 storm drwxr-xr-x 3 knox knox 4096 Dec 21 12:01 storm-logviewer drwxr-xr-x 3 knox knox 4096 Dec 21 12:01 webhcat drwxr-xr-x 3 knox knox 4096 Dec 21 12:01 webhdfs drwxr-xr-x 3 knox knox 4096 Dec 21 12:01 yarn-rm drwxr-xr-x 3 knox knox 4096 Dec 21 12:01 yarnui
5.) I stopped knox, moved the /deployments/default* and started knox again, but still the same problems.
Thanks,
Andreas
Created 02-17-2017 07:06 AM
I did the curl command from 2.) from one of the cluster nodes (internal). I tested it now from my client pc with the following command:
C:\01_Data\curl\src>curl curl -i -k -su <my_user> -X GET "https://<our_knox_host>:8443/gateway/default/static/bootstrap-3.0.2/js/bootstrap.min.js" Enter host password for user '<my_user>': HTTP/1.1 404 Not Found Date: Fri, 17 Feb 2017 07:01:45 GMT Set-Cookie: JSESSIONID=174cdd7p72bdupmc98his5fcr;Path=/gateway/default;Secure;HttpOnly Set-Cookie: rememberMe=deleteMe; Path=/gateway/default; Max-Age=0; Expires=Thu, 16-Feb-2017 07:01:46 GMT Content-Type: text/html; charset=ISO-8859-1 Cache-Control: must-revalidate,no-cache,no-store Content-Length: 342 Server: Jetty(9.2.15.v20160210) <html> <head> <meta http-equiv="Content-Type" content="text/html; charset=UTF-8"/> <title>Error 404 Not Found</title> </head> <body><h2>HTTP ERROR 404</h2> <p>Problem accessing /gateway/default/static/bootstrap-3.0.2/js/bootstrap.min.js. Reason: <pre> Not Found</pre></p><hr><i><small>Powered by Jetty://</small></i><hr/> </body> </html>
The Oozie UI is the only one which is working, Oozie is installed on the same node like the our knox gateway. Maybe there is a problem by accessing the NameNode host or Ranger host from the knox gateway (knox host).
Created 02-17-2017 10:28 AM
Could be network although I would have expected a different error. Maybe there are other errors in the logs pointing to a connectivity issue?
I still don't see any dispatch in your log, that's the request Knox would make to the NameNode, do you see it in your audit log like in my example?
The second check, the curl -i http://our_namenode_host:50070/static/bootstrap-3.0.2/js/bootstrap.min.js, did you do it from the knox host?
I've seen weird behaviours in the past when HTTP proxies are configured, if you have one on the knox box, can you make sure the namenode host is on the NO_PROXY / ignore list?
With a proxy, your shell session / user / curl might be allowed to correctly make the request but knox would go via the proxy?
