Support Questions
Spark job running from a spark-shell fails with org.apache.spark.shuffle.FetchFailedException
Hi,
We have a CDH 5.12 kerborized cluster with 2 datanodes running a spark-shell from the edge node with master = yarn-client.
Using the sqlContext setup, we create a DataFrame using a simple SQL query.
scala> val df = sqlContext.sql("SELECT T1.PRVDR_NUM, SUM(T1.NCH_PRMRY_PYR_CLM_PD_AMT) FROM METASENSE_DATALAKE_vishal.CMS_IP_CLAIMS AS T1 group by T1.PRVDR_NUM")
df: org.apache.spark.sql.DataFrame = [PRVDR_NUM: string, _c1: double]
Following the dataframe creation with a simple df.show() action kicks of a spark job that results in org.apache.spark.shuffle.FetchFailedException and fails.
Below is the exception:
[Stage 0:============================================> (3 + 1) / 4]17/10/10 16:51:39 WARN scheduler.TaskSetManager: Lost task 0.0 in stage 1.0 (TID 4, ip-10-0-0-72.ec2.internal, executor 3): FetchFailed(BlockManagerId(2, ip-10-0-0-72.ec2.internal, 7337), shuffleId=0, mapId=2, reduceId=0, message=
org.apache.spark.shuffle.FetchFailedException: java.lang.RuntimeException: Failed to open file: /data01/yarn/nm/usercache/vishal/appcache/application_1507613154611_0799/blockmgr-d4f003e6-84ac-4357-8e10-a58b3d040c65/39/shuffle_0_2_0.index
at org.apache.spark.network.shuffle.ExternalShuffleBlockResolver.getSortBasedShuffleBlockData(ExternalShuffleBlockResolver.java:243)
at org.apache.spark.network.shuffle.ExternalShuffleBlockResolver.getBlockData(ExternalShuffleBlockResolver.java:147)
at org.apache.spark.network.shuffle.ExternalShuffleBlockHandler.handleMessage(ExternalShuffleBlockHandler.java:85)
at org.apache.spark.network.shuffle.ExternalShuffleBlockHandler.receive(ExternalShuffleBlockHandler.java:72)
at org.apache.spark.network.server.TransportRequestHandler.processRpcRequest(TransportRequestHandler.java:154)
at org.apache.spark.network.server.TransportRequestHandler.handle(TransportRequestHandler.java:102)
at org.apache.spark.network.server.TransportChannelHandler.channelRead0(TransportChannelHandler.java:104)
at org.apache.spark.network.server.TransportChannelHandler.channelRead0(TransportChannelHandler.java:51)
at io.netty.channel.SimpleChannelInboundHandler.channelRead(SimpleChannelInboundHandler.java:105)
at io.netty.channel.AbstractChannelHandlerContext.invokeChannelRead(AbstractChannelHandlerContext.java:308)
at io.netty.channel.AbstractChannelHandlerContext.fireChannelRead(AbstractChannelHandlerContext.java:294)
at io.netty.handler.timeout.IdleStateHandler.channelRead(IdleStateHandler.java:266)
at io.netty.handler.codec.MessageToMessageDecoder.channelRead(MessageToMessageDecoder.java:103)
at org.apache.spark.network.util.TransportFrameDecoder.channelRead(TransportFrameDecoder.java:86)
at io.netty.channel.DefaultChannelPipeline.fireChannelRead(DefaultChannelPipeline.java:846)
at io.netty.channel.nio.AbstractNioByteChannel$NioByteUnsafe.read(AbstractNioByteChannel.java:131)
at io.netty.channel.nio.NioEventLoop.processSelectedKey(NioEventLoop.java:511)
at io.netty.channel.nio.NioEventLoop.processSelectedKeysOptimized(NioEventLoop.java:468)
at io.netty.channel.nio.NioEventLoop.processSelectedKeys(NioEventLoop.java:382)
at io.netty.channel.nio.NioEventLoop.run(NioEventLoop.java:354)
at io.netty.util.concurrent.SingleThreadEventExecutor$2.run(SingleThreadEventExecutor.java:111)
Caused by: java.io.FileNotFoundException: /data01/yarn/nm/usercache/vishal/appcache/application_1507613154611_0799/blockmgr-d4f003e6-84ac-4357-8e10-a58b3d040c65/39/shuffle_0_2_0.index (No such file or directory)
at java.io.FileInputStream.open(Native Method)
at java.io.FileInputStream.<init>(FileInputStream.java:146)
at org.apache.spark.network.shuffle.ExternalShuffleBlockResolver.getSortBasedShuffleBlockData(ExternalShuffleBlockResolver.java:232)
... 27 more
at org.apache.spark.storage.ShuffleBlockFetcherIterator.throwFetchFailedException(ShuffleBlockFetcherIterator.scala:383)
at org.apache.spark.storage.ShuffleBlockFetcherIterator.next(ShuffleBlockFetcherIterator.scala:361)
at org.apache.spark.storage.ShuffleBlockFetcherIterator.next(ShuffleBlockFetcherIterator.scala:55)
at scala.collection.Iterator$$anon$13.hasNext(Iterator.scala:371)
at scala.collection.Iterator$$anon$11.hasNext(Iterator.scala:327)
at org.apache.spark.util.CompletionIterator.hasNext(CompletionIterator.scala:32)
at org.apache.spark.InterruptibleIterator.hasNext(InterruptibleIterator.scala:39)
at org.apache.spark.sql.execution.aggregate.TungstenAggregationIterator.processInputs(TungstenAggregationIterator.scala:511)
at org.apache.spark.sql.execution.aggregate.TungstenAggregationIterator.<init>(TungstenAggregationIterator.scala:686)
at org.apache.spark.sql.execution.aggregate.TungstenAggregate$$anonfun$doExecute$1$$anonfun$2.apply(TungstenAggregate.scala:95)
at org.apache.spark.sql.execution.aggregate.TungstenAggregate$$anonfun$doExecute$1$$anonfun$2.apply(TungstenAggregate.scala:86)
at org.apache.spark.rdd.RDD$$anonfun$mapPartitions$1$$anonfun$apply$20.apply(RDD.scala:710)
at org.apache.spark.rdd.MapPartitionsRDD.compute(MapPartitionsRDD.scala:38)
at org.apache.spark.rdd.RDD.computeOrReadCheckpoint(RDD.scala:306)
at org.apache.spark.rdd.RDD.iterator(RDD.scala:270)
at org.apache.spark.scheduler.ResultTask.runTask(ResultTask.scala:66)
at org.apache.spark.scheduler.Task.run(Task.scala:89)
at org.apache.spark.executor.Executor$TaskRunner.run(Executor.scala:242)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
Caused by: java.lang.RuntimeException: java.lang.RuntimeException: Failed to open file: /data01/yarn/nm/usercache/vishal/appcache/application_1507613154611_0799/blockmgr-d4f003e6-84ac-4357-8e10-a58b3d040c65/39/shuffle_0_2_0.index
... 27 more
at org.apache.spark.network.client.TransportResponseHandler.handle(TransportResponseHandler.java:186)
at org.apache.spark.network.server.TransportChannelHandler.channelRead0(TransportChannelHandler.java:106)
... 1 more
17/10/10 16:51:40 WARN scheduler.TaskSetManager: Lost task 0.0 in stage 1.1 (TID 6, ip-10-0-0-72.ec2.internal, executor 2): FetchFailed(BlockManagerId(1, ip-10-0-0-72.ec2.internal, 7337), shuffleId=0, mapId=0, reduceId=0, message=
org.apache.spark.shuffle.FetchFailedException: java.lang.RuntimeException: Failed to open file: /data01/yarn/nm/usercache/vishal/appcache/application_1507613154611_0799/blockmgr-2742a1a6-7cbd-46e4-8154-293ab27fcc22/38/shuffle_0_0_0.index
Caused by: java.io.FileNotFoundException: /data01/yarn/nm/usercache/vishal/appcache/application_1507613154611_0799/blockmgr-2742a1a6-7cbd-46e4-8154-293ab27fcc22/38/shuffle_0_0_0.index (No such file or directory)
... 27 more
Caused by: java.lang.RuntimeException: java.lang.RuntimeException: Failed to open file: /data01/yarn/nm/usercache/vishal/appcache/application_1507613154611_0799/blockmgr-2742a1a6-7cbd-46e4-8154-293ab27fcc22/38/shuffle_0_0_0.index
... 27 more
... 1 more
17/10/10 16:51:41 WARN scheduler.TaskSetManager: Lost task 0.0 in stage 1.2 (TID 8, ip-10-0-0-72.ec2.internal, executor 3): FetchFailed(BlockManagerId(2, ip-10-0-0-72.ec2.internal, 7337), shuffleId=0, mapId=2, reduceId=0, message=
... 27 more
... 27 more
... 1 more
17/10/10 16:51:41 WARN scheduler.TaskSetManager: Lost task 0.0 in stage 1.3 (TID 10, ip-10-0-0-72.ec2.internal, executor 4): FetchFailed(BlockManagerId(1, ip-10-0-0-72.ec2.internal, 7337), shuffleId=0, mapId=0, reduceId=0, message=
... 27 more
Here is the Spark configuration:
spark.dynamicAllocation.enabled true
spark.dynamicAllocation.executorIdleTimeout 60
spark.dynamicAllocation.minExecutors 0
spark.dynamicAllocation.schedulerBacklogTimeout 1
spark.eventLog.dir hdfs://ip-10-0-0-247.ec2.internal:8020/user/spark/applicationHistory
spark.eventLog.enabled true
spark.executor.extraLibraryPath /opt/cloudera/parcels/CDH-5.12.0-1.cdh5.12.0.p0.29/lib/hadoop/lib/native
spark.executor.id driver
spark.externalBlockStore.folderName spark-08c7a6d2-eb56-40eb-b198-735d73c665d7
spark.extraListeners com.cloudera.spark.lineage.ClouderaNavigatorListener
spark.jars file:/home/vishal/.ivy2/jars/com.databricks_spark-csv_2.10-1.5.0.jar,file:/home/vishal/.ivy2/jars/org.apache.commons_commons-csv-1.1.jar,file:/home/vishal/.ivy2/jars/com.univocity_univocity-parsers-1.5.1.jar
spark.lineage.enabled false
spark.lineage.log.dir /var/log/spark/lineage
spark.master yarn-client
spark.org.apache.hadoop.yarn.server.webproxy.amfilter.AmIpFilter.param.PROXY_HOSTS ip-10-0-0-247.ec2.internal
spark.org.apache.hadoop.yarn.server.webproxy.amfilter.AmIpFilter.param.PROXY_URI_BASES http://ip-10-0-0-247.ec2.internal:8088/proxy/application_1507613154611_0799
spark.repl.class.outputDir /tmp/spark-e0de2a11-5402-48ec-8379-e190febe6ca0/repl-6fb66657-7680-4fd6-82db-3d7aa1daf641
spark.repl.class.uri spark://10.0.0.36:34996/classes
spark.scheduler.mode FIFO
spark.serializer org.apache.spark.serializer.KryoSerializer
spark.shuffle.encryption.enabled false
spark.shuffle.service.enabled true
spark.shuffle.service.port 7337
spark.sql.queryExecutionListeners com.cloudera.spark.lineage.ClouderaNavigatorListener
spark.submit.deployMode client
spark.ui.enabled true
spark.ui.filters org.apache.hadoop.yarn.server.webproxy.amfilter.AmIpFilter
spark.ui.killEnabled true
spark.yarn.am.extraLibraryPath /opt/cloudera/parcels/CDH-5.12.0-1.cdh5.12.0.p0.29/lib/hadoop/lib/native
spark.yarn.config.gatewayPath /opt/cloudera/parcels
spark.yarn.config.replacementPath {{HADOOP_COMMON_HOME}}/../../..
spark.yarn.historyServer.address http://ip-10-0-0-247.ec2.internal:18088
spark.yarn.historyServer.allowTracking true
spark.yarn.jar local:/opt/cloudera/parcels/CDH-5.12.0-1.cdh5.12.0.p0.29/lib/spark/lib/spark-assembly.jar
Yarn configuration:
yarn.nodemanager.resource.memory-mb=30720
yarn.scheduler.maximum-allocation-mb=4096
yarn.scheduler.increment-allocation-mb=1024
yarn.scheduler.minimum-allocation-mb=512
yarn.scheduler.maximum-allocation-vcores=8
yarn.scheduler.minimum-allocation-vcores=1
yarn.scheduler.increment-allocation-vcores=1
yarn.nodemanager.local-dirs=/data01/yarn/nm,/data02/yarn/nm
yarn.resourcemanager.nodemanagers.heartbeat-interval-ms=1000
The dataset we are using to perform the task is not very huge (~18MB). We don't see any OOM errors. The executors are terminated due to SIGTERM.
We notice that the shuffle file is actually created on data node 1 but the executor was looking for it on data node 2 and failing.
[root@ip-10-0-0-82 ~]# ll /data01/yarn/nm/usercache/vishal/appcache/application_1507613154611_0799/blockmgr-d4f003e6-84ac-4357-8e10-a58b3d040c65/39/shuffle_0_2_0.index
-rw-r----- 1 vishal yarn 1608 Oct 10 16:51 /data01/yarn/nm/usercache/vishal/appcache/application_1507613154611_0799/blockmgr-d4f003e6-84ac-4357-8e10-a58b3d040c65/39/shuffle_0_2_0.index
We are not sure what could be causing this issue. Please help.
1 ACCEPTED SOLUTION
Hi there,
Thank you for following up. We have identified the cause and resolved it. Our DNS was setup incorrectly. This issue can be closed.
Thank you,
Vishal
7 REPLIES 7
Expert Contributor
Can you verify that shuffle auxilary service is enabled within YARN?
Also, please make sure you do not see any issues with host devices like Out of Space on disk or Java GC issues.
We don't see any storage space issues. The we two local.dirs setup on two mount volumes. and both of them have more than 400 GB free space. I don't see any Java GC issues as well.
I am using the following link to monitor the GC charts:
http://10.0.0.247:7180/cmf/services/18/charts#q=Concurrent Mark Sweep Garbage Collection Time Across NodeManagers
Please let me know if we have to monitor anything else in addition to this.
Thanks,
Vishal
Hello,
Yes, the shuffle auxillary service is enabled. Also, the external shuffle service for spark is enabled as well.
yarn.nodemanager.aux-services.spark_shuffle.class to
org.apache.spark.network.yarn.YarnShuffleService
Thanks,
Vishal
Rising Star
Hi Rabk,
What the log4j WARN message provided shows is a task thats failing with a FetchFailedException because a shuffle file (shuffle_0_2_0.index) can't be found, it does not show what the job fails with or what transpires during the job run. But lets assume that the job fails when a stage has failed 4 times because of the fetch failures.
One possible cause for the FetchFailedException is that you are running out of space on Nodemanager local-dirs (where shuffle files are stored), so look at the Nodemanager logs (on datanode 2), from the timeframe when the job ran, for bad disk/local-dirs messages. When this happens, YARN will send a SIGTERM to the containers/executors, like you have observed. Are you able to run the query on just a fraction of the current data or does it succeed if no other jobs are running on the cluster?
Hello,
As I mentioned in one of my earlier replies, there is more than 400 GB space available on configured local.dirs.
We do see the queries run successfully sometimes. But most times, we are seeing the file not found exceptions. The tasks are being retried before being given up.
I have yarn logs from two of my previous test runs. I will send them to you for futher analysis.
Also, I will try running the shell again and capture more logs.
Thank you,
Vishal
Hi there,
Thank you,
Vishal
